About updating
Hydrops
About updating
Post by Hydrops »
hi
I don't think I've ever updated the controller, controller's version currently is V7.21.5-2018.02.8, is it up to date
If not do I need to ?
If so how do I update with the downloaded files ?
Thank you
Hydrops
Re: About updating
Post by Hydrops »
anyone ?
Re: About updating
Just go to DSP software download and check up the software
viewtopic.php?f=55&t=3773
Hydrops
Re: About updating
Post by Hydrops »
Hi
Today Lasersoft switched into chinese language, don't know why didn't do anything
I tried to install 7.22.23 for T9 DSP but keep getting the following error
I installed the drivers as recommended, what am I missing here ?
I also notice this new install will install in a new 7.22.23 folder meaning i will then have two versions installed is this how it should be ?
And how can I switch back to English language ?
Thank you
Hydrops
Re: About updating
Post by Hydrops »
Hydrops wrote: Mon Jul 13, 2020 2:47 am Hi
Thank you
No need to reply to this, just reinstalled the OS which seems to have solved the problem
Return to “DSP T9”
