dsp lo x7 problem with files with lot of curves
a77an
Postby a77an » Sat Sep 01, 2018 12:39 pm
hi! i am having this issue for a log time and i can not solve it, when i cut files with lot of curves the curves sometimes misses de aligment
Re: dsp lo x7 problem with files with lot of curves
Postby Tech_Marco » Sat Sep 01, 2018 4:18 pm
Please post your parameters for the manufacturers and the user setup. It seems that it was caused by mechanical issue.
Check laser head, mirrors, lens, and mirror. Those items may got loose somewhere. X7 won't do that for sure.
a77an
Postby a77an » Mon Sep 03, 2018 10:29 am
its not a mechanichal issue because it only happends with big files with lot of curves, i update the firmware and cut it again and it was ok, i hope that doesnt happend again.
