Looking for any videos on importing PLT files that were created in CorelDraw & then sent to LaserCad. Not having the best of luck yet. File imports without the Vector outline, or if it is, I am doing it wrong.
Also, how does the CorelDraw plugin work? Will it laser exactly as it was created in CorelDraw once it is imported to LaserCad?
(I do not have the correct version of CorelDraw to use this feature) but I can upgrade if it integrates better.
CorelDraw to LaserCad, new Light Object laser
steinco
htrowrod
Re: CorelDraw to LaserCad, new Light Object laser
I see that this is an old post. Did you ever get this solved? Can you export a DXF instead of a PLT?
Bruce
Bruce
