Communications Error
BanksCNC
Postby BanksCNC » Thu Apr 12, 2018 9:50 pm
So I've had a T9 for about 6 months and all has been working great until recently. All of a sudden i'm starting to get a " Communications Error" in the middle of a job. Screen goes red and the laser stops. Once I powercycle the laser it will recover from the error and continue...ill get abit more done on the job and it happens again...and again...and again....What is causing this error? what Can I do to fix it?
Brandon Banks
Re: Communications Error
Postby Tech_Marco » Fri Apr 13, 2018 9:22 am
Hi
Check the connection cable between the LCD and the main board. I think a lose connection between your PC and the controller should’ show communication error once job was transferred successfully, The only possible issue the data cable between the main board and the LCD. Just lose two screws, unplugged it and plug it back. Then secure the two screws and give it a try.
Let me know if it fix the issue
BanksCNC
Postby BanksCNC » Fri Apr 13, 2018 9:47 am
Awesome...Seems to be working for now :-) Thanks Marco
Postby Tech_Marco » Fri Apr 13, 2018 9:52 am
smile
Return to “DSP T9”
