Text engraving problem
ichliebekohlmeisen
Postby ichliebekohlmeisen » Sun Apr 01, 2018 3:16 pm
I setup a new file to engrave some text. In the past it would scan an entire line like an inkjet printer, now it is engraving one complete letter at a time. File was .svg created in Inkscape. I converted all my objects (text) to paths, and opened the file in Raycam. Set my text color and selected engrave. Did I change a setting accidentally?
Re: Text engraving problem
Postby Techgraphix » Mon Apr 02, 2018 5:15 am
It's a setting somewhere, i changed it somewhere in the past, but i can't remember exactly what it was... something like BMP-optimize.
But i can't reproduce it anymore else i could tell you.
You have to search in that direction anyway..
ichliebekohlmeisen
Postby ichliebekohlmeisen » Mon Apr 02, 2018 6:41 pm
I’ve run it with bmp optimize on and off, no difference.
Postby Tech_Marco » Sat Apr 07, 2018 3:37 pm
Check or unchecked the "Auto Group" should take care your issue
