Hi Guys,
I am using the machine with the USB disk only. Have no problem to load the file into machine.
Now in case I am not happy with the settings within the file - is here a way to change those settings in the machine itself or do I need to reprogram the file on the PC ?
For example - suppose I drew a box and set the power to 50% and speed to 200. Doing the cut I see I need to change the speed to 100. Is there a way to change the speed to 100 when re-running the file without having to go back to the PC ?
Changing the settings on the main menu does not help me because when re-running the file, the speed goes back to 200...
Am I doing something wrong ?
Cheers
Isaac
Changing *.ud5 parameters - SOLVED
neuman5022
SWMS
Re: Changing *.ud5 parameters
You’ll have to resend the file from the PC.
neuman5022
Re: Changing *.ud5 parameters - SOLVED
No, I don't
Here is what I did and it works fine for me:
1. On main screen you hit ENTER
2. Set cursor to FILE and hit ENTER - this will bring you to FILE PARAMS SETTINGS
3. Arrow down to LAYER PARAMS SETTINGS - and press ENTER
4. Arrow down to SPEED (MM/S) change numbers and DO NOT FORGET TO PRESS ENTER.
This will change your file speed settings when re-running the file.
This should be done to every layer (colour) you want to change speed and/or power settings.
Cheers
I.
Cheers
I.
