Coreldraw plugin for Version X8
ramos
Post by ramos »
Hi,
Has anyone else been to get the coreldraw plugin from the 7.86.1 setup file for LaserCAD to install? I have not been able it keeps giving a "path is incorrect error" when doing auto-install, even if I do manual it still fails with the same error.
If anyone does have it could you post the plugin directory up somewhere so I may download it.
Thanks!
Ramos
SWMS
Re: Coreldraw plugin for Version X8
Post by SWMS »
Do you have access to a Corel Draw x7 installation? You can copy the files from there. If not. Pm me and I will give you a hand.
It's easy and you don't need the installation once you know how.
