Hi,
I bought the 612 and starting to hook it up.
the K type TC works fine
but a pt100 shows EEEE
I checked the resistance of the pt100 and it is 115 ohm
any idea?
which terminal connection should i use?
thanks
PT100 connection problem [Solved]
dovaleh
dovaleh
Re: PT100 connection problem
just found the solution:
from http://www.jimsbeerkit.com/forum/viewto ... &sk=t&sd=a
connected the 2 wire pt100 to 8 and 9, and also connected 9 and 10
best
dov
best
dov
