JLD612 using a PT100 Thermocouple
Aaron
Post by Aaron »
I am using this set up for a home immersion circulator, When I try and set my PID to the PT100 I get EEEE on my display, the only one that seems to not produce an error code is selecting the E Type. Also when programming how do I see this in .1 degrees C? I am using the plans for the DIY Sous Vide machine from Seattle food geek and am trying to get this up and running for a catering event I have comming up. Any help would be great. Thank you for your time in advance.
Re: JLD612 using a PT100 Thermocouple
You have to use a matched sensor type in order to work. You can't select PT-100 if the sensor is E type or K type. Doing so will end up "EEE.E" over loaded error
