Hello All,
I upgraded my K40 laser cutter last year to the LO-X7 DSP and have not had any issues since the upgrade. The other day however I ran into an issue..... I was running a cutting job and the x-axis stopped moving. I power cycled the DSP, double checked parameters but found no issues. On a fresh power cycle I am able to jog the axis with no issues. After trying to run a file it stops working and then I am unable to move the axis even trying to jog. Again if I turn off power and try again all works until I try to run a file. Cut or engrave it produces the same result. I have not changed any setting so I am confident that is not the issue. I have also tried swapping the x/ y drivers and I see the same result on the x-axis with the other driver connected. Could I have a bad DSP card only after a few months use? Please help!
LO-X7 DSP X-Axis Problem
Steve_M
Jump to
- Special note
- Administrative Category
- ↳ New Product on the board
- ↳ Latest News
- Sell & Wanted
- ↳ Laser products
- ↳ CNC products
- ↳ Electronics products
- ↳ Others
- ↳ Repair & Upgrade
- ↳ Product Lab
- ↳ Cutting & Engraving tips
- ↳ FAQ (laser)
- ↳ AWC7824
- ↳ AWC7813
- ↳ Ruida R6445G/X
- ↳ DSP T9
- ↳ DSP X7
- ↳ DSP R5
- ↳ DSP E5
- ↳ DSP 608
- ↳ CO2 Laser Discussion
- ↳ News
- ↳ Auto focus laser head
- ↳ Introduction
- ↳ CNC zone
- ↳ Temperature Controller
- ↳ Electronics
- ↳ RF Wireless Controller
- ↳ Digital/ Analog Meter
- ↳ Laser & CNC products
- ↳ DSP controller
- ↳ Water Chiller
- ↳ Laser power supply
- ↳ XY gantry and frame
- ↳ Motor driver
- ↳ K40 small laser
- ↳ LCD Module
- ↳ AC Power Frequency Meter
- ↳ Other electronics devices
- ↳ Water pump
- ↳ LED
- Software Download
- ↳ DSP Laser Controller
- ↳ Fiber Laser
- ↳ Flying
- ↳ Others
