HELP please! how to make a belt
Badfrog
Postby Badfrog » Wed Mar 16, 2016 9:06 am
I am building a rotary attachment for my K40... I need a custom length belt; after cutting belt material to the correct length, how do you connect the ends of the belt?
laserdude
Re: HELP please! how to make a belt
Postby laserdude » Wed Mar 16, 2016 4:33 pm
You can't glue a belt!! It must be a complete belt without any cuts. Instead, you need to add a tensioner to use a belt one standard size longer.
SWMS
Postby SWMS » Mon Mar 21, 2016 3:23 pm
Bad frog. You don't. You attach each end to the carriage that you are moving and work out some way of clamping it down. Remember it's not like a pulley system that moves over the pulley. It's only going back and for.
laserdude
Postby laserdude » Wed Mar 23, 2016 10:34 am
For a rotary attachment, Badfrog needs a continuous belt that rolls over pulleys. Clamping the ends is not possible.
Return to “Others”
