Page 1 of 2
Out of Bounds / Scaling Issue AWC608
Posted: Wed Mar 09, 2016 3:30 pm
by pourcirm
I'm having an odd scale related issue I can't solve.
I have my LaserCAD software configured for my 500 X 700 laser bed and on my laptop I draw a few shapes that are small and well within the cutting area. I then upload the file to my DSP, when I try to run the file it tells me it's too large and something like out of bounds. When I say yes continue anyway it cuts a portion of the shapes at a much larger scale. When it gets to the physical edges of my laser bed it cuts a straight line and basically crops the shape. Circles are cut as half circles and come out as D's along the top edge of my laser bed when on the cut file I created the circle is in the middle of the board nowhere near the edge.
When I move the laser manually from the control panel it can reach all the way to 500 X 700 with no issues and knows that's how big the laser bed is. For some reason it appears as though somewhere between LaserCad and DSP the cut file is being scaled or modified so that it's outside of the defined bounds.
Anyone have any ideas on how to correct this issue?
Re: Out of Bounds / Scaling Issue AWC608
Posted: Wed Mar 09, 2016 5:38 pm
by DonL
Sounds like the UM settings are way off, Perform a teest, draw a box 50x50mm thew measure the box, the um settings in the system options have a ... buton, use it and enter the size you asked for (50) and the size you measured and it will tell you the proper um adjustment
Posted: Thu Mar 10, 2016 8:04 pm
by pourcirm
See that's the odd thing though, I configured the UM settings already. When I'm in LaserCAD and I use the Machine Control toolbar I can give the machine exact X and Y coordinates and it moves the expected distances. So when it's at 0,0 and I tell the laser to move to 25,25 it moves almost exactly 25 mm on the X and the Y axes.
I only have the weird scaling issues and the "Out of Bounds" error when I try to run an actual file downloaded from LaserCAD to the DSP on the laser.
Any other thoughts?
Posted: Fri Mar 11, 2016 3:32 am
by DonL
If you draw a box that is 50x50mm and you get anything different, the um calibrration must be out or you have the wiring mixed up or there is a setting that is way off somewhere Double check your wiring then run the calibration on a 100x100 box, if the box is not 100x100 check settings and calibrate UM
Also make sure that your checkbox for rotary is unchecked or it will use those um calculations...
You could have a faulty controller but I have not heard of that yet
Posted: Fri Mar 11, 2016 3:12 pm
by pourcirm
If my UM was configured wrong the LaserCAD Machine Control toolbar wouldn't move the laser properly. I know the UM settings are correct, I ran test distances to dial it in. I've seen UM setting problems on the CNC and 3D printer I built previously, if the UM settings are wrong the laser would either not move enough or move too much and crash into things. When I use the toolbar to move the laser 50mm the physical laser head moves 50mm in both X and Y directions.
When I try to run a LaserCAD file it prompts me with the "Out of Bounds" message before any movement even starts and when I hit enter to continue the job the movements are adjusted for the known 500 X 700 bounds of the laser table. The head doesn't crash into anything it simply runs up to the edge of the cutting area and then moves along that edge in a straight line.
This has to be something in the software that is improperly processing the LaserCAD files I'm drawing. It's essentially taking the 500 X 700 drawing I'm creating and convincing the DSP that the file is larger and the DSP compensates to keep within the bed so nothing crashes.
Posted: Fri Mar 11, 2016 4:01 pm
Did you setup the "machine zero", "page zero", and "Position relative" to match the location of the limit switches (X,Y)??
If not, do it first. I have listed the problem on 'FAQ', did you read it and try it?
Or, post your image and the location of the image on the machine so we can take a look of that.
Posted: Fri Mar 11, 2016 8:01 pm
by DonL
Can you Take some screen shots of your parameter settings and let's see if there is something out of wack
Posted: Sun Mar 13, 2016 6:49 am
by pourcirm
Alright so first here's my current settings:
- Laser Settings.png (45.97 KiB) Viewed 6154 times
- Laser Settings 2.png (24.83 KiB) Viewed 6154 times
I think those are set up properly because everything moves as expected when I manually control the laser as noted previously. If there's something I'm missing though I'm more than willing to change some settings and test whatever suggestions you all have.
The issue I'm running into will hopefully be explained below, the first picture is a crude example of what I'm drawing in LaserCad, all home positions and bed size properties are correct and there shouldn't be an issue cutting the shapes.
When I download this file to my DSP and try to run it I get a message saying "Out of Bounds", I hit enter to run it anyway so I can see what the file looks like and below in the blue box is what it actually runs. It's as though it's scaling up the entire file and it runs everything inside the blue box much larger that it should be. When it moves to the edge of my cutting bed it chops the shape off, so in this image I end up with a circle that has a flat side.
Thanks for any help you can offer.
Posted: Sun Mar 13, 2016 8:43 am
I want to see the User Parameter as well
Btw, acceleration for both X and Y seems slow. Make it faster. I don't what kind of machine you have. So, I can only do guessing
No hardware info provided
X: 8,000
Y: 3000
Posted: Sun Mar 13, 2016 10:28 am
by pourcirm
I haven't really worked on the acceleration and other "speed" or "laser power" settings as I'm still finishing the overall build. At one point they were too high and I hadn't dialed in the UM settings so the laser head kept crashing into the endstops too hard so I turned the acceleration down then. I kind of forgot to turn them back up. The laser is based on the BuildLog.net 2.X Laser if you're familiar with that. A lot of people from the forum purchase DSP's from you so that's where I got the initial suggestion.
Here's my User Params, I haven't done much here as far as making changes.
- Laser Settings 3.png (38.91 KiB) Viewed 6148 times
Posted: Sun Mar 13, 2016 10:52 am
You should use either Normal or fastee setting on that model.
Just select Normal and click "Instant recovery" . The current setting on your User parameters seems too slow. The machine may not got enough time to pick up speed
What speed did you use for the sample and got the error?
Posted: Mon Mar 14, 2016 3:24 pm
by pourcirm
I'll change those settings this evening.
I got the error using all of the settings that I've posted here so far.
Posted: Sat Mar 19, 2016 9:03 am
by pourcirm
I tried changing the settings noted above and the DSP is still not functioning as expected. Still get the "Out of Bounds" message before the file will run, when I confirm I want to run it anyway it only runs a small portion of the actual drawing from LaserCAD and the scale appears to be wrong too.
Posted: Sat Mar 19, 2016 9:11 am
Please send me the User parameters and manufacturer parameters. Before doing so, please click "Read"
I am quite sure it is a setting issue at somewhere
Posted: Sun Mar 20, 2016 8:38 am
by pourcirm
