temp controller connections to kiln
iszarv
Post by iszarv »
I have the 64 set point temp controller. Does anyone know how to connect to a kiln? If not this temp controller, any other ssr type.
bill
cumorglas
Re: temp controller connections to kiln
Post by cumorglas »
assuming you are using single phase, run the hot leg through the ac side of the ssr, then look at your diagram on the controller and figure out which ones are for the ssr output. pos to pos neg to neg.
