LaserCad corel plugin problem
Posted: Wed Jan 06, 2016 3:29 am
by nony
Hi,
i noticed little problem when exporting drawing from corel to lasercad with plugin..
I have 2 layers. 1. is bitmap for engraving, 2. is curve for cutting.
if I export it, there is nothing in lasercad. Just layers. But no image, or curves. See attachment.
if I export bitmap first without curves, i can see it in lasercad.
Re: LaserCad corel plugin problem
Posted: Wed Jan 06, 2016 8:41 pm
by DonL
I had noticed that as well but it seems to be OK now using Corel X7 and LaserCAD 7.78
I just tested a Corel layout with a jpg, a text, and a text converted to curves and all three items transfered to LaserCAD 7.78 OK
Posted: Wed Jan 06, 2016 10:46 pm
by nony
OK, i will try to update my lasercad. Thank you
Posted: Thu Feb 04, 2016 4:01 am
by nony
So I updated to latest version, but no luck with this problem...
But I realized problem is when you have Guidelines in your Corel file.
When you use lasercad plugin on vector with guidelines, no data is imported to lasercad.
You have to remove all guidelines.
Maybe in next version they can fix this by ignoring guidelines :-)
Best
Frantisek
Posted: Thu Feb 04, 2016 7:42 pm
by DonL
nony wrote:So I updated to latest version, but no luck with this problem...
Best
Frantisek
NICE FIND! I had occasions where grapics would not transfer but I don't use gude lines much so today I tried it, I added a .jpg and a Vector to a layout and sent it to Laser CAD, worked just fine, then I added guide lines to each and sent it again and low and behold.... Nothing transfered at all! :eek:
NO GUIDE LINES - COREL X7
no guides.JPG (68.34 KiB) Viewed 3120 times
TRANSFER TO LASERCAD WORKS
WITH GUIDELINES COREL X7
guides on.JPG (66.11 KiB) Viewed 3120 times
TRANSFER TO LASERCAD FAILED
