PHCad password?
Chris
PHCad password?
Post by Chris »
Hello!
I bought a DSP Controller from you in 2011.
PH-Board V2.0
The Software needs a Password for the manufacturer parameter.
I tried some from your PDF-Files but no one worked.
Can you help me?
Best regards from Austria!
Christoph
P.s. sorry for my bad English
Re: PHCad password?
These are code that I have:
811104 (Master key code to release demo time)
9xfc88 (Write)
or
"634590"
Chris
Re: PHCad password?
Post by Chris »
Thank's a lot.
I'm going to try them tomorrow morning.
Chris
Re: PHCad password?
Post by Chris »
Dear Marco!
First of all thank's again for your quick response!!!
I tried all of the passwords, but no one works.
I've got a PH-BOARD V2.0
S/N:A#PH#30962
and the old blue HMI
I tried a new Software from SZPUHAN.com (Laser engraving and cutting software V7.02)
This one shows me the parameter, but I'm not able to write them without the password.
The old PHCad V4.38 dosn't even show without password.
I've also got some other problems.
After starting the origin search the step motor goes to the Limit Switch. After a few Seconds (after reaching Limit Switch) it goes into the other direction.
It looks like the machine is going to search a second Limit Switch.
I also bought Step Motor Driver from you.
2 pc 6560T2V1
I've got a 1,2A 0,9° Motor for Y and a 0,3A 0,9° Motor for X.
Can you tell me how to set the DIP-Switches?
The resolution is defined by Mod. 1/2/8/16 but I don't know which one is 0,9°
Can I set the current to 0,6A and decay to 50% to get 0,3A?
Thank you very much for your help!!!!
Christoph
Chris
Re: PHCad password?
Post by Chris »
Found the password in the forum!!!
ph123
