I was going to order the adjustable z table for my K40 and I intend to use the threaded holes in the platform as a pin table. Can someone confirm the thread size of these hole so I can make/buy standoffs that will fit? I'm assuming they are something like M4?
Thanks!
K40 Adjustable table LSR-PWRTB320 thread size
lapoltba
Re: K40 Adjustable table LSR-PWRTB320 thread size
M3 can pass through freely while M4 is too big to fit into the hole. But, if you want to thread the hole, then it is good to make thread hole for M4 screw
lapoltba
Are the threaded or just straight through? Unthreaded is even better as I can make them whatever I want.
Not threaded. Can't afford to put threaded holes
lapoltba
Perfect! Thanks Marco!
