Hello,
Is there any way to check which wires from lpsu are for PWM and TL ( gnd is obvious black )
I have YM LS120 power supply with no diagram, ( it is from yue ming laser that i upgraded to X7)
i opened the LPSU, there is no marking on board , just connector.
On LPSU is DB9 connector.
Is there a way to test to find which wire is what?
I have pictures from old board ( with wires connected) but terminals are just numbered ( i can't download diagram from ymlaser because that file is missing.
Thanks.
LPSU reverse engineering from db9 connector
limatech
limatech
Re: LPSU reverse engineering from db9 connector
Thank you Techgraphix
Laser fires when i press test on power supply, when connected to DSP absolutely nothing.
I just dont want to waste more time so i just ordered http://www.lightobject.com/80W100W-PWM- ... V-P73.aspx
After tube, DSP, lenses, etc. and now power supply i hope to start cutting soon.
