water pump control
soviatt
water pump control
Postby soviatt » Wed Jul 22, 2015 10:59 am
I want to setup a variable speed pump for testing that I can control using a 0-10v dc signal (from a PLC) . I am limited with the current from the control signal to 175mA. I want to be able to pump about 1gpm and vary the speed of the pump using the 0-10v dc control signal. I have the PLC, and both a 12v and 24dc power supplies. What would you recommend to as far as a pump, and a driver to power/control the pump.
Re: water pump control
Postby Techgraphix » Wed Jul 22, 2015 1:21 pm
first: what kind of motor you want to controll?? AC/DC 24V or 230V~ ? Power??
A small electronic circuit can be simple solution..
Return to “Others”
