We have developed a newer model water chiller: LO-1600W
The cooling power is summarized as following:
1) Support a 150W tube in continuously mode (non-stop)
2) Support two 150W tubes in normal operation
3) Support four Reci 80W in normal operations
4) Support two 120W tubes in continuously mode (non-stop)
Compare to CW5200, our chiller control unit is a micro-processor control with large LCD display instead of a simple LED control. It comes with a more powerful compressor and better quality parts. The freon is DuPont R410A which is RoHS.
We will roll out a dual head model and smaller model on next ocean shipment. The smaller model is good for a single 120W running in normal operation. Plus, we will carry some water evaporator cooler (no compressor) which is good for up to 60W tube or 3KW CNC router
LightObject 1600W Water chiller
