need help with DC-KIII CO2 laser engraver
wiccanpride
i purchased the DC-KIII CO2 laser engraver a little less then a year ago and have had no luck with it at all ..... i have sense learned that the Moshi software is crap so i would like to change out the board and controllers i see many kits on this site but was hoping some one could help me to find the kit that should work with my machine
Re: need help with DC-KIII CO2 laser engraver
hi there
I would recommend to buy the X7 kit it will fit in pretty much every machine.if you need more help send me a PM
wiccanpride wrote:i purchased the DC-KIII CO2 laser engraver a little less then a year ago and have had no luck with it at all ..... i have sense learned that the Moshi software is crap so i would like to change out the board and controllers i see many kits on this site but was hoping some one could help me to find the kit that should work with my machine
wiccanpride
can i run the x7 kit on my normal 110 power or do i need to upgrade to 220
you have to specify what voltage you need
wiccanpride wrote:can i run the x7 kit on my normal 110 power or do i need to upgrade to 220
