A new ocean shipment is booked. Following is a brief item list
40x SP 60W CO2 tube
10x SP 80W CO2 tube (1250mm)
40X SPT 80W CO2 tube (1250mm), peak power 105W!
10X SPT 100W CO2 tube (1450mm)
10x SPT 130W CO2 tube (1600mm)
20x LightObject 1600W water chiller AC110v
2x LightObject 1600W waterchiller AC 220v
1x 1800x1200 laser machine
1x 1200x900 laser machine
5x XY stage 600x400
5x XY stage 900x600
2x XY stage 1200x900
5x XY stage 1800x1200
300x 20W LED T8 florescent light
5x 900x600 body frame
100x Honeycomb 300x200
100x Honeycomb 600x400
40W, 60W, 80W, 150W Laser power supply
And more.....
New ocean shipment on June 20th
Re: New ocean shipment on June 20th
The shipment arrived this morning at 10:30am. We spent almost 2hrs to unload it.
I want to introduce a new 80W tube "C80" (1.6m) CO2 laser tube from SPT. With current at 28mA, the output power could be as high as 120W!!
It does need a special requirement though. It must driven by 100W or higher power laser power supply. If you're using a regular 80W PS, you still can get that much output but the power is overloaded and won't last long. This tube is great for doing cutting
