Will this item
http://www.lightobject.com/High-precisi ... -P795.aspx
work with this machine
http://www.ebay.com/itm/CO2-LASER-ENGRA ... fresh=true
Quick question about LO rotary device
liltritter
liltritter
Re: Quick question about LO rotary device
and does anyone know the lens size on this machine and if I am better off with the LIghtObject one?
It is up to the machine but not to the rotary. All rotary (depends on single axial or dual ), they share similar concept. It is just matter of size of the rotary if it fit in or not. In that matter, I don't think anyone know without a try of putting the rotary in the machine. You may need to ask the seller how deep it is and if 3rd motor driver installed or not. If not, then you may need to disconnected "Y" and hope it up to the rotary. Of course, you need to determine the "um" value on the controller card or it won't work right
