AWC708C can't see home switches
mroecks
Post by mroecks »
Hey Marco,
I have been using a new AWC708C for about a week, I just tried to boot the machine up and it homes but ignores both the X axis and Y axis homing switches. It stalls the steppers and can not finish booting.
I checked all the wiring and everything is ok there.
Is the controller blown?
Re: AWC708C can't see home switches
Double check the parameter setting to make sure the Limit switch is set to 'negative' triggering
Blown?? How could it be?
mroecks
Post by mroecks »
Checked parameters and they are fine.
Found out if I hit stop when it tries to home I can continue into a job.
Everything else works fine. It is just ignoring the inputs from both the X and Y axis.
MrWoodyCrafts
Post by MrWoodyCrafts »
I have the same problem, still working on it, New X7 with new table, found bad micro switch, no help.
Anybody figures it out let me know I'll do same.
Woody
