Dps with servo motors?
Detroit
Will the dps run the servo motors if I us a gecko g320x ?
tnt76
Re: Dps with servo motors?
Yes absolutely!!
I am running a moog c13 motor with HEDS 500 PPR encoder x-axis
Yasakawa motor and HEDS 500PPR encoder on Y-axis
Both through gecko 320x drives.
Detroit
Thanks I have a epilog summit that I want to convert the tube went out and I have the motors and wanted to use them
tnt76
What servo's are you running on the summit?
I converted an Epilog legend 32, 50watt to an 80watt RECI and added the LO DSP because the Epilog control screen was unreadable. Bought for $600.
Detroit
It has Pittman servos on it I also have a uls25 I'm going to convert also
