I need to measure, with Programmable Triple Displays Digital AC Single Phase Power/ Watt Meter current from less than one amp to over six amps. I've bought the 100/5 transformer. What number of turns should go through the transformer, and how to program the meter.
Thanks, Cornell
Use of Current transformer
audiodoctor
Re: Use of Current transformer
You don't need to do turns on the coil. Just pass the line through the hole will do 20:1
You should download the manual to learn how to program it
