Import issue with Adobe Illustrator AI file and LaserCAD
Posted: Fri Dec 20, 2013 6:44 am
by TimAustinTX
I have tried to import multiple Adobe Illustrator AI files into LaserCAD and I an getting the same weird box off the workspace grid.
I have tried to save them as different versions of Illustrator with the same result.
Any help would be appreciated.
Tim
- 2013-12-021.jpg (194.07 KiB) Viewed 1958 times
Re: Import issue with Adobe Illustrator AI file and LaserCAD
Posted: Fri Dec 20, 2013 7:27 am
by Axeman
I've always exported them out of AI via DXF. That almost always solves my problems =)
Posted: Fri Dec 20, 2013 8:13 am
by TimAustinTX
That makes sense I will go that route!
Posted: Fri Dec 20, 2013 8:45 am
by TimAustinTX
So exporting the file from Illustrator as a DXF works but it is not holding the dimensions.
How do I get LaserCAD to hold the dimensions?
Thanks again!
Tim
Posted: Fri Dec 20, 2013 9:23 am
by TimAustinTX
Another issue I am running into is lettering is not transferring over even though I have the font installed on both machines.
Tim
