Hi!
I bought a 22'' Touch-Overlay for my LCD-Monitor. Now when I wanna set it up, the mouse goes to the left when i swipe my finger to the left and it goes to the right when I swipe it to the right. But when I go up the mouse goes down and vice versa. In addition the mouse is always about 2 - 3 inches above the point i touch the panel. Because of that I am unable to configurate.
Please help!
Niklas
22'' LCD Touch Kit
Ortenberg2013
Re: 22'' LCD Touch Kit
What about use the other side of the panel? Or, revese the connector and try it
Stephen6309
You need to run the calibration program. It should have been installed with the driver.
Ortenberg2013
Thanks for your replies.
Using the other side of the panel does not work because there's just one side of the panel that is touch-sensitive.
I also tried to get it work with the other side of the connector. Same thing...
