Communication between DSP and PWM power supply do not work
Sesijama
Post by Sesijama »
Hi
Test on PWM power supply is OK. Laser tube make laser beam.
But if I send data via DSP control unit no laser beam.
Laser is on DSP panel activated.
Connection diagram:
DSP AWC 608 power supply IP-40
laser1
3 - PWM IN
4 - TTL L
5 - GND G
Please help.
Re: Communication between DSP and PWM power supply do not wo
Don't forget to connect "WP" to thr ground to simulate water is activate
Sesijama
Post by Sesijama »
Tech_Marco wrote:Don't forget to connect "WP" to thr ground to simulate water is activate
Perfect! Thats it!!
Thank you
