no movement or laser
euroflo1970
Post by euroflo1970 »
Hi
I have my system all wired up and powered
The stepper motors are locked, but I have no movement using either the panel or the software, the laser will not fire either.
I have checked, and rechecked all the wiring, confirmed 24V from the power supply to the drives, green light is on.
the computer is communicating to the DSP.
Should I send back the AWC 608 board to get checked out..?
thanks
I have ordered another DSP control and power supply from you. I have too much work waiting to be done at the moment and cant afford too much down time. I will get this other board in the post to you to have a look at
Re: no movement or laser
I emailed you to ask you to check the `um` value but I didn't get reponse from you. I bet you didn't the manual I sent you, didn't you.
What kind of machine or motor are you using?
You need to have proper setting to make it work
euroflo1970
Hi Marco
Yes I set the um value to 5 as per the instructions. I fear what might of happened is the 40W laser power supply had a short to earth. Although the safety circuit triped before I was electricuted, it might have damaged the drive chips on the board.
Or, and it could have damaged the drive aswell.
I have some spare drives here that I will test with
No I didnt get your email, for some reason the forum doesnt like my email address. Please use euroflow2000@yahoo.com.au
Justin
UPDATE
Well I have just done some testing, looks like it blew the drives, so I now have motion. it looks like I have a signal from the DSP to the laser power supply, so it must just be that, that is holding me up.
Did you receive the 2nd DSP card yet?
Let me know the progress
