I would also like to know how I go about mounting the lens and mirror assemblies? I'm in the UK so want to be sure to order everything I need if the assemblies in my machine can't be reused.
While we're here:
1. This product isn't listed in the section for "D/K Small Machine Parts" so while I stumbled across it, I was kinda lucky to do so. It probably ought to be included in that section.
2. Can I suggest you change the name of the product as it implies a 300x200 working area whereas the product blurb says it's 300x220. That extra 20mm is VERY important to me because the issue that I have with my current set-up is that I can't cut an A4 sheet (297x210)... which is obviously a commonly available size for materials. For your customers in the USA, the ability to accommodate US letter size (215.9 mm × 279.4 mm) is probably equally important; making that extra 20mm crucial once again I ignored the 300x200 stage the first couple of times I looked in that product section, thinking that it wasn't big enough... when it turns out that it's exactly what I'm looking for (provided it will fit in my machine).
