ECNC-SC04 single axis stepping motor controller/ tester
This is a stepping motor controller ideal for using as a motor tester. With four controlling modes, it can control a stepper motor in forward, backward, mutiple swing or single swing. Low cost but very handy. It is great to be used as a power 'Z' table controller. By the way, you can use this board for different size steppers by using proper motor driver (not included).
- StepperController500.jpg (124.04 KiB) Viewed 16982 times
- ECNC-SC04.pdf
- (396.85 KiB) Downloaded 1682 times
