Hey guys, I have read the forum looking for help, and I am a bit of a noob. I could use some help wiring my thermocupler and pid / ssr. Everything I am trying doesn't seem to work.
I have a pt 100 thermocouple
http://www.lightobject.com/Water-resist ... -P592.aspx
I had a mypin TD4 PID that was given to me.
http://www.mypinchina.com/uploadfiles/2 ... 316698.pdf
I also have the SSR.
http://www.lightobject.com/25A-Solid-St ... -P314.aspx
1. This thermocouple has two green wires and one red wire. The end connects on the red wire is red, the end connect on the green wires are blue. I connected the blue connectors to terminals 7 & 8, then the red connector to terminal 9 on my pid.
2. I cut a computer power supply cord into sections, and ran the wire from the male plug outlet - black wire to terminal 1, and white wire to terminal 2. on my pid
3. I used a 6 inch section of the power supply cord, and ran a white wire from terminal 3 on my pid to terminal 4 on my ssr.
4. I did the same as in step 3, except used a black wire from terminal 4 on my pid to terminal 3 on my ssr.
5. last, i connected a power cord female connector to my SSR. White wire to terminal 1 on my ssr, and black wire to terminal 2 on my ssr. However, I have never received power from this plug. It is not hot when the SSR light is on.
I believe this is a PT 100, so when I program my PID - on inty, i set the value to pt, but the reading is like -400 F. If i set the inty value to y, the reading is like 80 degrees F. At room temp and my room temp is 70. If i drop the thermocoupler into a glass of ice water, it drops to 79.2 when the inty value is y...
Could use some help from you guys.
How to wire the Waterproof PT100 RTD Thermocouple to my PID
averagejoe
Re: How to wire the Waterproof PT100 RTD Thermocouple to my
The Pt100 is a resistance temperature detector, or RTD. Its red connector goes to terminal 7. The blue connectors go to terminal 8 and 9 -- doesn't matter which goes to which.
Terminal 3 on the controller goes to terminal 3 on the SSR -- plus to plus
Terminal 4 on the controller goes to terminal 4 on the SSR -- minus to minus
AC from the wall goes to Controller terminals 1 and 2 -- color is unimportant.
AC from one side of the wall plug -- call it black -- goes to SSR terminal 1
SSR terminal 2 connects to one terminal on the heater
The other terminal of the heater connects to the other side of the wall outlet -- call it white.
In order to use the SSR, the part number of the controller MUST have a "2" as the next to last number -- this is a model with a 0-10VDC output, which is what the SSR needs to have.
Hope this helps.
Hope this helps.
averagejoe
Thank you so much. I finally got it wired! The output is a plug so that I can plug in various heating elements (slow cooker, roaster, etc)
Any tips on how to program the PID, I have it programed as a PT controller... Any other tips?
One thing I notice now is that the light on the SSR flashes quite a bit around the desired temperature. Is there a way to change this? I am just concerned that the power kicking on and off for 1 second thousands of times in an hour will not be good for my roaster.
