Just got my laser build finished today, and started playing with it. Loving the dsp so far!
I have some files that I need to cut, which need dotted score lines cut in them. Doing these in .5mm chipboard (like cardstock but thicker)
I have everything setup in corel properly, but when I hit the start laser button and it sends the file over to lasercad, I lose that dashed line style from Corel. Is there any way to maintain this? Or even better send the file to the laser straight from Corel (print driver or something maybe?), the only buttons I got in Corel from the macro are "Laser Start" which sends the file to LaserCad, and "Import DST/Dsb Data". I should also mention I'm using Corel Draw X5 on windows7 64 bit.
I'm not sure how to tackle this, since the dashes need to be cut not engraved, so I can't rasterize them or anything.
Any help would be most appreciated.
