macro in autocad and coreldraw
Jacala
Post by Jacala »
Hello,
I've been searching on this forum but could not find a straight answer.
I'm trying to get the macro's in both corel draw and autocad but without succes. I've reinstalled lasercad but to no avail.
In the download section of this forum there are also no drivers.
So, how do I fix this? With lasercad the dsp is working GREAT. I really like it but now I want to cut some board for my dsp, on/off switch etc. Thats why autocad comes in. Nice and perfect for the job
(there is no real measurement function in lasercad is there?)
twehr
Re: macro in autocad and coreldraw
Post by twehr »
Jacala wrote:Hello,
In the installer, did you select the installation you want from the drop-down menu?
javawantabe
Post by javawantabe »
I get "can't find coreldraw". Anyway to override it or force the install, or extract the macro?
agrasyuk
Post by agrasyuk »
Hi guys,
I seem to have the same issue. i trying to install PHCad software with autocad pluging but get the message that it cann't find Autocad. what folder the software expects to find?
Post by waltfl »
Hi my friend
you need to re install the PHcad software and select the version with autocad.
agrasyuk wrote:Hi guys,
concretevapor
Post by concretevapor »
strange thing. doesnt want to work. i have autocad 2013, trying to install the lasercad plug-in.
i have windows 7 by the way
i have installed lasercad v6.27 successfully, but i cant import anything into lasercad. and still have problems installing the autocad plugin.
2 message windows appear
"copying files......waiting"
"can't find autocad"
good sunday
As I know, the macro in current LaserCad only supports CorelDraw X5 and AutoCad 2008. If you have X5, the macro won't work. I have asked Li (the programmer) to look into this issue. Will let you guys know once an update is availabe
