4CH RF Remote Control Tx/Rx Kit (module)
wdwray
Post by wdwray »
This refers to the remote reciever without relays (also known as basic stamp).
Please explain how this device functions.
For example, first, I connect a power source (5v) to the +5v and GND terminals. That part's pretty clear. Assuming I have a momentary on version, what then happens at terminals VT, D0, D1, D2, and D3 as I press each button on the remote?
Thanks in advance.
Re: 4CH RF Remote Control Tx/Rx Kit (module)
D0,D1,D2,D3 is the output
VT is an indicator for the output
Why not download the manual and read it?
wdwray
Post by wdwray »
Tech_Marco wrote:D0,D1,D2,D3 is the output
I did download the manual- and it isn't very clear on what is output; that's why I asked the question. So, it seems VT goes to +5v (or whatever V+ voltage is) when one presses any one of the buttons. So what do the outputs do? Does the output corresponding to the button pressed also go to +5v?
Again, it's an indicator for the action. You can use it or without. It's really up to you. It's +5V whenever a button is press
