I'm the Physics / Physical Sciences coordinator for our Regional (and sometimes State) Science Olympiad. This year, I needed to construct a water bath that could maintain a constant 65C or better (key is "constant") water temperature throughout the day.
I purchased the JLD612DC (the AC was out of stock), a 25A SSR, and PT100 "premium" probe.
As I write this - I've only just fired-up the low voltage side and confirmed no fuses blow, lights glow, and things otherwise look happy. I'm still terrified to light up the line-voltage side.
The project is built in a cheap $10 Harbor Freight toolbox with appropriate holes cut in it. Once functionality is confirmed, everything will get a good dose of RTV. I'm looking for splash resistance. The AC output plug is a 15A GFCI outlet housed in an in-use wet-environment exterior box. The input is fused with a 15A ceramic fuse.
The input cord is a cannibalized 10AWG/10ft extension cord. All internal AC wiring is 12AWG.
The DC input is a barrel plug in the opposite side, and is fused with a 2A Buss fuse.
Switches are lighted Radioshack, 12v automotive and 120vAC as appropriate.
The bath will be a 12Qt Allclad sauce pan, and the heater is a 1200wt GE electric hot plate, decades old from my college dorm days.
The event is this weekend, and I'm totally out of time. I tossed this together this morning, and plan to have it hopefully working and tested tonight. That considered: comments welcome!
More updates as testing continues.
