Where is autofocus PIN onf AWC 608 ????
bluewave65
Hi,
Where is a autofokus input pin on AWC608 ????
I searched whole forum and nothing .....
Dave
Dave
bluewave65
Where is autofocus PIN onf AWC 608 - MARCO ????
Marco don`t know ???????????????????????????
I don`t understand why lightobject sell DSP with autofocus feature ,but there is no information on manual about it, no information from lighobject .......... just no information about anything anywhere .....
MBF
Re: Where is autofocus PIN onf AWC 608 ????
Hi
I just received my DSP and had the same problem as you, but playing around for a while I found out that You user ELZ+ for autofocus. I'm not 100% sure because my machine is not finish yet and can not test it
/Mike
/Mike
Ruud Hogenberg
Hello Bluewave65, MBF
Can you explain how autofocus will work and eventually where i can buy a set, starting to build new machine within few weeks and this options looks interesting to me.
Thank you
Ruud
www.gippetto.com
Thank you
Ruud
www.gippetto.com
Programer Li
in LCD, press ã€ÂÂZ/U】->ã€ÂÂAuto Focus】, Z-axis will move at the speed of ã€ÂÂZ-axis reset speed】, stop till touch Z+ limit switch, and then move the distance as inã€ÂÂFocus distance】in opposite direction.
Ruud Hogenberg
Hello Li,
Thanks you for your answer, i was in the assumption that autofocus is a tool you can install and that the machine automatically goes to the focus hight..
Meaning it will automatically move up or down the z axes, is this correct?
Ruud
www.gippetto.com
Ruud
www.gippetto.com
Not really. It is used for adjusting the distance between the laser head and the surface of an object that you want to do engraving or cutting. When you press "auto focus", the X-Y bed will move up till it hit the "Z" sensor , stop then backward to the distance you set say 6mm.
It doesn't mean that the laser head or the X-Y bed moving up/down automatically. It only serves the first time you run the auto focus
FYI, usually the distance between the object and the laser head is 6mm~9mm. But it depends on the type of laser mount and the focus lens 50.8mm or 75mm you're using.
shizyo
Sorry its an old post but got a question about it. I suppose when the focus lens is 50.8mm, the distance from the laser head to the surface of the object should be 50.8mm. Why would it be 6mm?Tech_Marco wrote:FYI, usually the distance between the object and the laser head is 6mm~9mm. But it depends on the type of laser mount and the focus lens 50.8mm or 75mm you're using.
Jetguy
Easy, Marco is just saying the tip of the nozzle NOT the lens which is higher up will be 6-9mm above the surface with the MUCH shorter stock lens that comes with K40s and such.shizyo wrote:Sorry its an old post but got a question about it. I suppose when the focus lens is 50.8mm, the distance from the laser head to the surface of the object should be 50.8mm. Why would it be 6mm?Tech_Marco wrote:FYI, usually the distance between the object and the laser head is 6mm~9mm. But it depends on the type of laser mount and the focus lens 50.8mm or 75mm you're using.
You correctly pointed out the surface of the lens to surface is the correct measurement. Some folks may not be smart enough and think the lens is the whole assembly and measure from the tip of the air nozzle, not the actual location of the lens in the assembly. Further, you really do want the air assist nozzle to be about that height for best function. He's not wrong, just he made his explaination more for the lay person with the typical hobby machine.
