Larger tube for D40 or K40 (1000mm tube upgrade)
Tim
Re: Larger tube for D40 or K40 (1000mm tube upgrade)
Post by Tim »
Are these cabinet extensions going to be made again any time soon? Lowering the mounts seems like a simple milling job. One could also create all new mounts if desired. You could even add some shim stock to the mirror mounts to make up the difference.
-Tim
Have ordered 50units.
My staff in China will send me 5~10 units at a time till an ocean shipment booked and I can import in a lot
It may take 3 weeks to receive the small order so be patience.
Tim
Post by Tim »
I'm committed now, I cut a 4-1/2" hole in the body. I used a hole saw from Lowes and a .5 amp, 1/2" drill. It worked out very well.
-Tim
Hole for 1000mm Tube
hayesjl77
Post by hayesjl77 »
Tim wrote:I'm committed now, I cut a 4-1/2" hole in the body. I used a hole saw from Lowes and a .5 amp, 1/2" drill. It worked out very well.
-Tim
I did the 1000mm tube upgrade today just waiting for a case extension. sticks out about 15 inches when mounted right.
Tim
Post by Tim »
Do you have any photos?
-Tim
hayesjl77
Post by hayesjl77 »
tricky! :eek:
Find a decent cover fast...
hayesjl77
Post by hayesjl77 »
Techgraphix wrote:tricky! :eek:
Still waiting on LO guys to get the covers in lol.
Tim
Post by Tim »
My cover came in and I have a few comments. The hole pattern is accurate but they don't match the drawing. I'm glad I waited for the cover before drilling the mounting holes. Once mounted, the assembly is very sturdy. There is no need for additional gussets. I've painted mine to match the machine. Rust-Oleum "Sail Blue #7724" is a pretty close match. Buying the cover is a no brainer if you are going with the 1000m tube.
-Tim
hayesjl77
Post by hayesjl77 »
This is what it looks like. Mounting was perfect with a 4 inch hole centered on the back chamber.
RomeoKilo
Post by RomeoKilo »
I'm in the market for a new tube and thinking i might as well go this route.
Question- Was it worth the upgrade to a larger tube?
In the real world have you noticed enough of power gain to justify the cost?
I'm ready to click on buy, just after some persuasion.
PeterE
Post by PeterE »
Any news on this?
Peter.
Q*bert
Post by Q*bert »
hayesjl77 wrote:This is what it looks like. Mounting was perfect with a 4 inch hole centered on the back chamber.
So how do you like your 45W tube? Is it noticeably better than the stock K40 tube?
OzAdr1an
Post by OzAdr1an »
I got one of these tubes Mid-2016, which means its the 55mm one not the current 50mm one. Did anyone who had this one end up just shaving down the current mounts, or was there a better approach found ?
Cheers
Adrian
Tim
Post by Tim »
I was able to use the stock mounts and simply adjust the mirrors. Your mileage may vary.
-Tim
