help with connection driver 2M5042 to DSP
Re: help with connection driver 2M5042 to DSP
Post by waltfl »
Hi tim,
hmmm the bigest probleme what I have now is that the computer does not connect with the DSP. I try three computer 1 with windows XP, and two with windows 7 I even have installed the new 64 bit driver from today
but nothing of them works.
I have un-installed and re- installed a few times the laser cut and even try this with the ph programm nothing ether
do you have a idea ?
thanks
twehr wrote:
waltfl wrote:thanks tim
today I get the new motor then I will try it out.
but in the mean time the screen shots of laser cut 5.2 is not exactly the same as PHcad.
thanks again
Pulse Width and Pulse Unit are the same thing. It should be about 25.4 (for 200 step motors which are what you likely have). If you are set at 3.x then that is why your motor is not working correctly.
