Looking Pinout for Channel 1 and 2 from Controller to Display LOX7 DSP
Re: Looking Pinout for Channel 1 and 2 from Controller to Display LOX7 DSP
OrangeClockwerk wrote:Marco! I found the problem, im so happy! It was the only possibly thing i could think other than a bad board, which i knew it worked so something had to be wrong. My controller cables must have had a wire issue when i shortened them, I remade a new set of controller cables and boom it was working! it was a last ditch effort but im now fully functional! The machine moves in all the right direction, homes to the correct corner, limits work and all i have to do is calibrate steps on the motors.
Once my machine is all working properly I will get my work logs up which will be basically a work work instruction on how the build, detailed descriptions on how to wire, and calibrate a 1200x900, 100w kit.
Good!. ;)
Users browsing this forum: No registered users and 44 guests
