lasercad v. 6.81 does not show PPI selection box
Post by waltfl »
Hi
since a few days the PPI selection box in lasercad v. 6.81 is greyed out . I did uninstall and re-install but it does not help.
what's the reason and how to fix it?
Re: lasercad v. 6.81 does not show PPI selection box
Post by waltfl »
hi marco
this problem still exist the PPI box is greyed out and I can not select it.
I tried what you had recommend with the changing in the cfg file but it did not help.
any other suggestion?
I don't use this a lot but ones in a while I would need it.
thanks
Walt, I don't see that happened on my PC. I installed the V6.81 and the PPI wasn't grayed out
Seems you may need to uninstall the LaserCad, remove the whole folder completely, then make a fresh installation again.
ArmandoMEX
Post by ArmandoMEX »
Dear Marco,
I am having same issue regarding PPI grey box. I have LaserCAD V6.89B I´ve tried unistalling and reinstalling several times but I PPI box remains grey and unavailable. Any suggestions?
Thanks.
Sorry, I don't know because I didn't supply you LaserCad v6.89
