do not match the incisions or cuts
maxpalmer1971
Post by maxpalmer1971 »
I have a problem when I carve or cut more objects, not the same, I'll explain: the first incision and cutting are fine but the second moves only engraving and cutting remains where it should be, the third is even more moved. may depend on what?
I need help, thank you.
engraving esempio2.jpg (22.92 KiB) Viewed 3039 times
It is not the alignment, when it affects you move slightly to the right (Image1), even if I do the engraving in the same place (image2)
engraving esempio1.jpg (28.85 KiB) Viewed 3039 times
Last edited by maxpalmer1971 on Tue Jun 04, 2013 10:25 am, edited 2 times in total.
TheKackler
Re: do not match the incisions or cuts
Post by TheKackler »
Sounds like your laser alignment worsens as you travel away from your laser.
just a thought.
maxpalmer1971
It seems that is was an mechanical issue. How fast you ran it
If it wasn't running fast and it happened,it could be a motor issue.
What resolution did you use onthe motor driver; 1/2, 1/8, 1/16... you may want to try 1/16 see if it fixit
One more thing you can try. Change the falling edge/rising edge see if it fix it. If X was in falling edge, change it to rising edge
MarCo
maxpalmer1971
my steping motor is set to 1/16.
140 to engrave speed and power of 10%. and it always worked.
I tried to do as you told me, but it did not work me is worse.
I motato a new problem, all you carve is distorted (see the logo of the study 54 photo 2) and instead cut what is right.
the engraving of the logo and made ​​from top to bottom, I also tried from below upwards, but it is worse.
I checked all the straps and screws but that's okay.
I reversed the microstep 2m415 but nothing changes.
might be a firmware problem?
Users browsing this forum: Bing [Bot] and 3 guests
