Stepper Motor Driver Question
mixer911
Post by mixer911 »
I have 2 KL 6050 Stepper Motor Drivers. I am building a LO 1200x1800 gantry at the moment with the DSP 2012 and 608B. Will these drivers be ok? Do I need 1/32 step modes? Here are the specs of them.
KL-6050 Bipolar Stepper Motor Driver:
Heat Sink is included.:
SPECIFICATIONS:
1: Supply Voltage 24 up to 60 VDC Output
2:Current: 1.5A,2.0A, 2.5A,3.0A,3.5A,4.0A,4.5A,5.0A
3:Step Modes: 1/2, 1/8
4:Suitable for 4, 6, 8 wires motors
5: Micro Step, Current Adjustment via DIP Switches
6: Over-Current, Over-Voltage & Short-Circuit Protection
Re: Stepper Motor Driver Question
1/8 seems a little bit 'big' for the stage. I highly recommend 1/16 (3200) or 1/25 (5000). Doing cutting would be fine with 1/8 but for engraving, the artwork may be a little rough. Well, you may give it a try as other specification seems Ok. If it work out as expected, then use it and no need to waste money.
Lightobject.com
mixer911
Post by mixer911 »
Thanks Marco,
I think I am just going to use a stepper driver capable of running at smaller steps. I will be cutting a lot of small circles in acrylic, so the smaller steps will prob be better.
