OS upgrade error
ltran2000
OS upgrade error
Post by ltran2000 »
Just install Lasercad 6.27 and have some error like motor strip,
, so I try to upgrade the OS to "120921V8.UG5" and V6,V7 but getting the message "upgrade error",
using 3 different usb 2G_FAT32, my mainboard: 5.11.10.30, LCD: 5.11.10.30,
1 thing I notice is the LCD keys not responsive like 2011 ver, when I turn-on and
it is homing and I press stop button and it not response, I have to press 2 or
3 time it will response and stop, I try to adjust space jerk and cut jerk to a lower
number and save but it come back to default anything else save ok.please help.
Re: OS upgrade error
Your version is very old and you can't upgrade the mainboard OS to the "120921V8.UG5" direct. You seems not following my post that you need to upgrade your mainboard to certain version before you can use "xxxxxxV#.UG5" file for future upgrade. BTW, you got to get the chip replace on the LCD unit if you need to get better control on Pan & Til movment. I posted the info back to 8 months ago that an upgrace chip is available for the LCD unit. In order to run LaserCad v6.xx, you have to upgrade the OS on the mainboard or there is incompatible may occur. Regardless upgrade or not, the LaserCad has nothing to do with the LCD control as it's a software (high level language), and it has nothing to do with the LCD uint (low level control). May be you should get the chip replace see if it can fix the problem.
I'm going to PM you two files see if helps (without LCD upgrade chip). Then, you start from there to run "xxxxxxV#.UG5". Note, you only need to run a file at a time per OS upgrade. Check the "V#" where the # will tell you what model of your mainbaord. It could be 6,7, or 8. FYI, now it's "7" unless otherwise.
ltran2000
Post by ltran2000 »
HI Marco
I replaced the LCD chip and now my LCD# 5.12.02.29 and i am able to upgrade OS
to Ver#2 and to V#6 but not#V7 or v8, mainboard now 6.12.09.21
now the problem I have is:
I reset everything and it seem work ok, but after I turn-off everything
and back on, I open the file that save to memory that work ok recently
and hit start ,the X_axis move all the way to right, i have to hit stop key, some
time it stop some time not, seem like the system not stable, I need to update to
a newer V8 or something. Thanks for your help
ltran2000
Post by ltran2000 »
HI Marco
Is v6 work ok with Lasercad 6.27 or I need to update to V8 ?
It's not matter of V6,V7,or V8 that you have as that is main-board group. V8 doesn't mean that it is more advance than V6.
After OS upgrade, you need to double check your setting again as it may reset to the factory default. For example, the XY direction may be reversed or the home location changed. Also, double check the "um" value.
Also, check your wire connection, especially the driver wiring and the limit switches. If it's working before, it couldn't be caused by the change of OS or software.
Post by waltfl »
Hi
I had this too but it is like marco says after any OS upgrade you need to resett all your settings.
I solved this probleme with saving the original settings on a extra place on the harddrive and after upgrading
I just read in manufacturer settings then import the old setting file and save it. this way I save a lot of time and agrivation.
ltran2000 wrote:HI Marco
Werner
Post by Werner »
Walt could you please give me the file name and where it is for the settings / parameter file?
Thanks for the help Buddy!
Werner
Post by waltfl »
Hi werner
I save the parameter file my self with the name manufsetLC here is mine
to set this : go to tools - manufacturer settings - read - then put my settings in - then save and export to your harddrive
Werner wrote:Walt could you please give me the file name and where it is for the settings / parameter file?
Werner
Thanks Walt for your effort. I found a better way to do it.
"File" -> "Export Config" and it will save all configration info of the main-board in one file (Manufacturer parameters & User parameters)
ltran2000
Post by ltran2000 »
Hi there
It seem working ok ,moving around,cut without laser, but I don't hook-up the laser tube yet,you said the key
responsive got nothing to do with OS but it is, when I upgrade to v2 it response with 1 press,when I upgrade
to V6 (now) i have to hit stop 2,3 time for it to stop(when homing) since I don't set-up limit switch yet.
Thanks every one for all the helps.
If that is the case, the OS must have something to do with the LCD unit. It's been a while I didn't remember well about it
My apology.
Post by waltfl »
Hi marco
where do you take the file from?? if you wana use the file for your settings how you wana import them to use it?
Tech_Marco wrote:Thanks Walt for your effort. I found a better way to do it.
You need to configure the card first befofe you export it. Use the "Import Config" to read the file under "File" from the LaserCad
SScnc
Post by SScnc »
I received the files you sent, thank you ! LaserCAD is now updated to V6.27 and seems to be fine.
However, I cant upgrade my AWC-608 with v6, v7, or v8, all report "Upgrade Error" on the LCD.
Do I need a new chip also ?
my information is as follows...
Order Number: 189799
Main board: 5.11.10.30
Lcd board: 5.11.10.30
Thanks for your help,
Steve
Your OS was very old. I posted an update for it about a year ago seems you didn't get it before the file was removed.
I'll send you it by email so you need to install the "pre-updated" OS before running the OS update
