What is the maximum thickness of objects that can be placed inside the Solo 40w Desktop Laser?
I have some box-like objects that I want to mark that are about 1.5" thick (3.8 cm).
Thanks, Jack
Max thickness of objects in 40w Solo
Jacko
Re: Max thickness of objects in 40w Solo
Hello Jack:
The default system doesn't has too much space but the you can remove the bed to get more space, up to 80mm. Or , you can add a power bed that I just developed in use with the solo. With the power bed, there is 6.5cm traveling space.
See the power bed: viewtopic.php?f=61&t=1232&p=4650#p4650
