2 volt module needs to read 100.0 with 1.000 volts input
rickety_goodman
Post by rickety_goodman »
I have an EPM-8145B2V (2 volt 8145 digital panel meter).
I want it to read 100 (%) when a potentiometer delivers
10 volts to a resistor wired in series with the input.
How do I determine what (input) series resistor will
reduce the 10 volt input to an apparent 1 volt input?
(i.e., what is the input resistance of the module?)
How do I move the decimal point over 2 places to
the right so that 1.000 volts input will show as 100.0?
rickety_goodman
Re: 2 volt module needs to read 100.0 with 1.000 volts input
I found some markings on the PC board saying that the 2volt
module has R2 = 100k and R3 = 11k.
If those are the input scaling resistors, then a 1Meg
resistor in series with the input would cause a 10.00 volt
signal applied to that resistor to display as 1.000 volts.
O.K.
Now, how do I move the decimal point over so that it
reads 100.0?
I see solder jumper pads D1 thru D4 and D1 is jumpered.
If I jumper D3 instead, will the decimal point move?
Also, what are the "F" and "H" jumper pads for?
F = digital filtration (noise reduction). Ideal for used in an application if a lof of static or electro-magnetic field happen to have. Enable it will slow down the display though
H = Hold. I think you can guess what it is.
I'm sorry I don't know about the resistor things as the manufacturer really don't want people to play around with it.
tonka1020
Post by tonka1020 »
I am also looking for a similar answer, only mine is from 20.00v to 2.000v. If I change D5, it jumps to 200mV max..
thoughts?
T
