Additional items needed to run 40 watt Mach3 laser engraver
randysworkshop
Post by randysworkshop »
What additional items do I need to successfully run this machine?
1. A printer cable (DB25 or Centronics connector?)
2. A computer running Mach3
3. A 220 volt AC power source (or does it come with a 110v. to 220v. transformer?)
4. A water chiller with a pump (what temperature?)
5. An air pump/compressor (What pressure and volume?)
6. An exhaust fan with ducting to the outside (What diameter connection and required CFM?)
Thanks in advance for your reply.
Re: Additional items needed to run 40 watt Mach3 laser engraver
1. DB25 cable (included)
2. March3 Release R3 and above
3. 110V > 220V Stepping up Transformer (800Watt ~ 1000Watt), not included
4. Pump include. A one gallon water container should be good enough. 30'C
5. Not support. We may customize one for a fee
6. Air blower included
randysworkshop wrote:What additional items do I need to successfully run this machine?
Users browsing this forum: No registered users and 73 guests
