http://www.lightobject.com/DC-to-DC-pow ... -P498.aspx
will this unit stay at the output voltage i set if the incoming voltage fluctuates.
say i set for 12v out and my input changes from 4-20 thought the day will it boost the voltage to 12 when its low and drop it when its higher than 12.?
i know the current will change also just wanting to know about the voltage.
DC to DC power module step up
buercky
Re: DC to DC power module step up
The voltage will stay the same. Just tried.
Say you setup the output is 15V, the output keep stay even if input is 8V,9V,..12V
Note: if input voltage is over than the output set point, then the output voltage will be following the input. Example: Set voltage = 15V. Input 16V ~ 20V. In that case, the output will be 16V~20V
buercky
ok looks like i need a BOOST and BUCK unit in one so that it stays at 12v regardless of in/out voltage
