Multiple lasers on one water reservoir and chiller?
TimAustinTX
Postby TimAustinTX » Sat Apr 15, 2017 6:49 pm
I have 4 (60W) laser machines I was thinking about running out of one large water reservoir and using a single large chiller (Lightobject 1600W Water Chiller).
Is there a reason that I should not do this?
Thank you,
Tim
SWMS
Re: Multiple lasers on one water reservoir and chiller?
Postby SWMS » Sun Apr 16, 2017 1:59 am
It will work in some form but if they are all running all day you might find the chiller will struggle. I wouldn't run them in series though. I'd try and do it in parallel.
Postby Tech_Marco » Sun Apr 16, 2017 9:19 am
You need to use 4x pumps to handle four lasers. Do NOT put those tubes in series or.... :!:
The LO1600W water chiller can handle two 150W tubes or 4x 100Ws working simultaneously. For that case, a separated pump is installed to handle each tube individually. A dual pump LO1600W is only available per request. We usually don't stock them
In your case, I'll have a 3 gallon reservoir acting as a 'buffer' tank and have four water pumps hooked up to the tanks. The chiller is cooling off the 3 gallons water instead of driving 4 tubes direct that connecting in series mode.
TimAustinTX
Postby TimAustinTX » Sun Apr 16, 2017 7:40 pm
The idea was to run a pump for each machine and a separate pump for the chiller just to circulate the water from the tank.
TimAustinTX
Postby TimAustinTX » Sun Apr 16, 2017 7:58 pm
You may get a better idea of what I was talking about with the drawing.
http://imgur.com/a/5rfWh
SWMS
Postby SWMS » Mon Apr 17, 2017 2:23 am
On a similar note. What are people using as an anti mould growth solution.
I've had issues with this, initially I thought it was algae. But after trying anti algae drops I found it wasn't algae but mould.
Options seem to be hydrogen peroxide, Milton or a few drops of iodine. Put a sterilising tablet in the buffer tank and wash it out before filling it with coolant. I'd also put a fine filter on the pump.
