K40 mini rotary. Higher quality made
000ooo000
Re: K40 mini rotary. Higher quality made
Post by 000ooo000 »
Hello and sorry for my bad english.
I want to buy the K40 mini rotary but I have some questions.
If DC-KIII the same as DK40? I have a 40w china engraver.
My DC KIII is in original condition. What do I need all around the K40 mini rotary to use ?
Is there somewhere a detailed instructions ?
I have translated with google translate
Many thx
Chris
DonL
Post by DonL »
Yes, Please go back 1 page to page 4 of this thread and the instructions with photos are here.
You need the Mini Rotary, A Stepper driver http://www.lightobject.com/Mini-2-Phase ... -P650.aspx
and some wire.
000ooo000
Post by 000ooo000 »
Thank you. What does this plug in on drawing one on page 4? And which wire I need?
Chris
DonL
Post by DonL »
000ooo000 wrote:Thank you. What does this plug in on drawing one on page 4? And which wire I need?
Chris
I used a Network CAT5 cable joining all the same colors together (yellow with strip joined to Solid Yellow...) and RG45 Plugs, You can use any 4 wire plug
000ooo000
Post by 000ooo000 »
The instructions on page 4 does not help me. From my Controller go 4 wires in the Y motor. How do I take DIR PULL +5V for the rotary driver?
Or do I have the y Rotary motor connect directly to the controller ?
Thanks for help.
I have this controller. Where should I install the Rotary driver there?
DonL
Post by DonL »
000ooo000 wrote:The instructions on page 4 does not help me. From my Controller go 4 wires in the Y motor. How do I take DIR PULL +5V for the rotary driver?
Thanks for help.
Sorry, The mods I gave are for the Light Objects Controllers like the LO-X7, not the Mushi Board. I am not sure if you can adjust the settings on the MushiDraw enough to use a rotoary. it is a very basic controller and the outputs are A+ A- B+ B- directly to the stepper motor. The stepper motor on the rotary may need to be changed to a lower amperage or you could fry the mushi board. I recomend you upgrade your controller.
flecky2006
Post by flecky2006 »
Hallo , und einen Schönen Guten Aben ;-)
Da es ja schon mehrere versucht haben die anscheinend wie ich Deutsch Sprechen , versuche ich es mal auf deutsch .
Hat jemand von euch eine Drehvorrichtung an einem K40 am laufen und könnte es kurz erklären ?
Evtl mit bilder , ich bin grad nicht sicher ob es bei meinem Board ohne einen Größeren umbau möglich ist ?
Ich bitte um hilfe , wenn es jemand umgebaut hat bitte ich um hilfe.
Google Translatet
Hello and a beautiful good Aben;-)
There have already several attempts apparently as I speak German, I try it once in German.
Has anyone of you a rotating device on a K40 run on and it could briefly explain?
Possibly with pictures, I'm not sure if it grade tag at my board without a bigger is possible?
I ask for help if someone has rebuilt I ask for help.
